Rfernandez23's avatar
Rfernandez23
Follower
Jan 26, 2019
ORBI RBR40 SLOW WIRED FILE TRANSFERS
Hey guys,
I had orbi now for at least 2 weeks and it  has been since day 1 that i've seen this slow transfer speeds between my pc and nas which both are hard wire to the main orbi router. Ive done factory reset, firmware updates and downgrades but nothing seems to fix the problem. Im mostly tranfering videos and music. But when i check speeds it gives 6 to 10 MB which is really slow.
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What devices are you using to xfer files and such?
    What is the mfr and model of the PC your using?
    Test with a different wired PC to compare?
    PC connected directly to router or satellite?
    What storage devices are you using if any?
    Any network switches in the mix?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    Rfernandez23 wrote:
    Hey guys,
