parramp's avatar
parramp
Orbi RBR40 VERY SLOW WITH BOTH ETHERNET AND WIFI
My Orbi RBR40 is operating very slow.
I have a 1GBS Fiber connection so I get 700-800 MBS both upload and download from the line in.
Through the router and ethernet to my pc, I am getting speeds in the 20-40 Gbs range download and 60-80 upload
Wifi is approximately the same speed
All of my firmware is updated and am running V2.5.1.22
This is terrible speeds, if I can only get this speed from this system, I am wasting my money on the 1Gbs service.
This system used to get ethernet speeds of 600-700 mbs download and upload and WIFI in the 250-300 range which was acceptable to me for wifi.
  • When did you notice the slow down?
    modem?
    was the Orbi firmware recently updated?
    • parramp's avatar
      parramp
      Noticed the slowdown at the beginning of December
      no modem, only cat 5 coming in from the router
      Router is the Orbi.
      It is definitely the router, because i direct connected the cat 5 to my pc and got over 800 download speed
      firmware update not recently, I am however running the most current version of the firmware
      • plemans's avatar
        You're actually not on the most recent. Not saying the version you're on is bad but the most current is 2.6.1.36
        Orbi RBK40 | WiFi System | NETGEAR Support
        And that fibre connects to some type of ONT. Do you know what ont/gateway it is?
  • plemans's avatar
    What gateway are you connected to?
    Make sure to have access controls, qos, parental controls, traffic monitoring all disabled. If they were enabled, disable and reboot the router.
    • parramp's avatar
      parramp
      None of that was enabled, and I did disconnect the power for 5 min and let the router reboot.
