Bielski
Apr 02, 2020Tutor
ORBI RBR40 with ARRIS BGW-210 Disables Circle - HOW DO FIX IT?
I just ugraded from cable to AT&T Fiber. They supplied me with an Arris BGW-210 modem. When I connect directly to the modem I get 940Mbps down/up. I connected my Orbi RBR 40 and speeds dropped a c...
Apr 03, 2020Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Your best option would be #3...
Circle has been problematic as of late.
Not review these threads:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/true#M68004
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
Bielski wrote:I just ugraded from cable to AT&T Fiber. They supplied me with an Arris BGW-210 modem. When I connect directly to the modem I get 940Mbps down/up. I connected my Orbi RBR 40 and speeds dropped a couple hundred Mbps. After doing some research I learned that I need to disable Wi-Fi on the Arris and enable IP passthrough. Done. Speeds are better, but not close to 940 Mbps. I next read that I need to set the RBR40 from ROUTER to AP modem. That brought the speeds up to around 940 Mbps, but he byproduct is that mmost of the setting have now been greyed out, and most importantly, Circle has been greyed out and disabled. How can I enable Circle while still maintaining the speeds that I'm paying for? Thanks!
