ATeamAdam
Mar 23, 2020Guide
Orbi RBR50 - instability issues
My kids have been complaining about our wifi for 2 years. Now that I'm working from home I'm feeling their pain. I've rebooted my router probably a dozen times in the last week. Purchased Octob...
- Mar 24, 2020
Thanks for the quick insight. Appreciate the guidance.
Any Wifi Neighbors near by? If so, how many? I do have a few wifi neighbors, depending on where you are in the house you can see about a half dozen signals, most of them are pretty weak.
I setup these settings after the factory reset. Hopefully it goes smooth.
New config:
2.4 Ghz Channel - 6
5 Ghz Channel - 48
Beamforming - enabled
MIMO - enabled
WMM - enabled
Armor - disabled
Circle - disabled
Daisychain - disabled
Fast Roaming - disabled
IPv6 - disabled
20/40 mhz coexistence - disabled
Short preable - enabled
ATeamAdam
Mar 24, 2020Guide
Appreciate the insights. I'll try the factroy reset tomorrow.
Is there a place I can look for best practices on manually configuring the Orbi? I have been running a pretty vanilla configuration and I figure this will be a good time evaluate better options.
Mar 24, 2020Guru - Experienced User
After doing a reset, and setting up from scratch. Be sure to save off a new backup configuration to file for safe keeping. Saves time when a reset is needed.
Some other troubleshooting suggestions to help with instability issues:
Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-model-RBR50-keeps-dropping-connection-during-Zoom-calls/m-p/1874136/highlight/true#M84647
ATeamAdam wrote:Appreciate the insights. I'll try the factroy reset tomorrow.
- ATeamAdamMar 24, 2020Guide
New config:
2.4 Ghz Channel - 6
5 Ghz Channel - 48
MIMO - enabled
WMM - enabled
Armor - disabled
Circle - disabled
IPv6 - disabled
- FURRYe38Mar 24, 2020Guru - Experienced User
Ok, let us know how it goes.
