RikParr73
Oct 12, 2018Aspirant
Orbi RBR50 - Poor Ethernet Backhaul on Satellites
Hi
I have RBR50 and 2 x Satellites. I also have Virgin Media Superhub 3, set in 'Modem mode'. Modem is on static 192.168.0.1 (Unable to change ISP set)
Satellites are connect via ethernet...
RikParr73
Oct 13, 2018Aspirant
Hi
Been away overnight, but back and shortly going into the loft to check the managed switch and will confirm active wired connections to the router and sats. I've notcied that my sonos speakers in close proximity to the sats are not connecting to the respective sat but the router which is further away, is that a sign there is an issue?
Many thanks, Rik.
ekhalil
Oct 13, 2018Master
Is there any wired Sonos speakers connected to the Router/Satellites? I had big issues when I had LG Speakers (part of an audio mesh system similar to Sonos) connected to the LAN port of the Satellite. https://community.netgear.com/t5/Orbi/quot-Wifi-Disconnection-quot-issues-are-still-in-2-2-1-210/m-p/1648667#M42790
- RikParr73Oct 13, 2018Aspirant
The Sonos Playbar and Sub are connected via ethernet, but directly to the managed switch, not to the router or sat....
