RikParr73
Oct 12, 2018Aspirant
Orbi RBR50 - Poor Ethernet Backhaul on Satellites
Hi
I have RBR50 and 2 x Satellites. I also have Virgin Media Superhub 3, set in 'Modem mode'. Modem is on static 192.168.0.1 (Unable to change ISP set)
Satellites are connect via ethernet...
ekhalil
Oct 13, 2018Master
RikParr73 wrote:
Indeed it is.
Even if you have to use Ethernet connection to Sonos, you should avoid wiring more that one speaker to avoid loop problems.
See this https://community.netgear.com/t5/Orbi/Orbi-with-SONOS/m-p/1468350/highlight/true#M19132
RikParr73
Oct 13, 2018Aspirant
Thanks both..
Thinking about it, I just went crazy during the house build making sure I could connect everything via ethernet. I will disconnect all the Sonos wired devices to see if that helps..
Furry, got to be honest, I've no idea about 'Hoopers and Joey's' lol!!...Let's see what the rest of the weekend brings :-)
Have a good evening, thanks, Rik.
- FURRYe38Oct 14, 2018Guru - Experienced User
LOL DISH neworks DVR and remotes is all. :smileywink:
Let us know how it goes.
