Paolo85's avatar
Paolo85
Follower
Oct 23, 2019
ORBI RBR50 - Speed issue through wireless connection
I have recently purchased a Orbi RBR50 (router + 1 satellite). When I test the internet speed at the router through the Orbi app I measure: download speed of 550mbps or above and upload of 900mbps or above. However I have tried to connect various devices in all kind of positions and distances in my apartment and the maximum speed I reach through wifi is ~300mbps. Is it normal to lose almost 50% of speed even when there are no obstacles between the devices?
  • FURRYe38's avatar
    What devices are you using to speed test? Wired or wireless? Wired PC is preferred.
    Try using Ooklas installable speed test app.
    Speed test with a PC directly connectec to the RBR.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(
  • Retired_Member's avatar
    Retired_Member
    Is it the actual 'speed' you're concerned about or the 'connection'?
    Do your devices work?  Can you reach the internet?  No bufferring?
