danspyvey
Jan 20, 2019Follower
Orbi RBR50 - Wired Connection to detached office
I have an Orbri RBR50 with one satellite that controls my home (network name orbi09). I have a detached office from the home that has no way of getting a wireless signal to it. I ran an ethernet wire...
orbira
Jan 20, 2019Apprentice
Instead of adding another router in wired office, I would just add another satellite over wired connection and pair it with the router in your home (unless your intention is to have a separate wifi network for your office and a separate wifi network for your home).
- Chuck_MJan 20, 2019Mentor
Agree with orbira -- why add another Router and make things more complicated? The entire purpose of Orbi is to solve problems like you have with distances.
The fact that you ran an ethernet cable is a huge bonus.... put an RBS-50 in there and call it good.
Your scenario is exactly what I had here... a distant outbuilding -- so I have an RBR-50 and two hard wired RBS-50s which work flawlessly (thanks to heroes in this community who have given excellent advice!)
- ekhalilJan 20, 2019Master
Agree with orbira and Chuck_M. You could have just added two satellites instead of a router and a satellite.
The catch is that you will need to use Daisy Chain for the other satellite to work wirelessly in daisy chain mode with the wired satellite which currently seems to cause issues sometimes. You could also wire the second satellite to the first satellite as alternative if possible.
Now that you already have a router and a satellite in the remote office, and since the router is set in AP mode and is wired to your home Orbi system you will see all devices connected to the office Orbi (the satellite as well as all other devices) as wired since the Home Orbi can only see the wired router from the Office Orbi and nothing more, since practically these are two different systems.
- CrimpOnJan 20, 2019Guru - Experienced User
I agree with the recommendation to simply connect the remote satellite to the Orbi router using ethernet cable. HOWEVER, the question asked was why the remote satellite shows up as "wired". I have an old Nighthawk R7000 in my garage set up as an access point to provide signal to some WiFi cameras that are too far from my Orbi for 5G to have a strong signal. EVERYTHING on the Nighthawk shows up as "Wired" on my Attached Devices screen. e.g. they are coming "through the wire" to the Orbi. Likewise, if I look on the Nighthawk, it shows everything on my Orbi as "wired".
