RWCaines
Mar 11, 2020Aspirant
Orbi RBR50 / 2 RBS50 satellites - WiFI speed extremely slow
We recently upgraded our Internet Service to 400Mbps through Spectrum but I can only obtain download speeds around 12-13Mbps over Wifi with the Orbi Router and two Satellites. What is also odd is tha...
RWCaines
The modem appears to be Spectrum's own, no other identifying markings on it. Connected directly to the modem, I am seeing speeds of 480 Mbps download and 22 upload.
Will have to check what i see hardwired to the Router, not easy to access, it is behind the TV in the family room
Thanks!
Mar 11, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Look for a sticker on the bottom?
Built in router and wifi here by chance?
- RWCainesMar 11, 2020Aspirant
I cannot see any identifying marks on the modem other than Spectrum. Modem and Router are separate. Router WiFi is off, using it simply to provide ethernet ports
Thanks
- FURRYe38Mar 11, 2020Guru - Experienced User
If there is a router built in to the modem, then this could also effect speeds between the modem and Orbi RBR. Even if wifi radios are turned OFF on the modem.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
RWCaines wrote:I cannot see any identifying marks on the modem other than Spectrum. Modem and Router are separate. Router WiFi is off, using it simply to provide ethernet ports
Thanks
- Retired_MemberMar 11, 2020
like I said....2.5.1.8 has some issues
- AmanSinghMar 18, 2020TutorI agree with you on 2.5.1.8, i have to factory reset every few days to get the speeds back. No fix provided by NetGear... waste of time and money
