jiac
Jan 16, 2019Guide
Orbi RBR50 & Bose Soundtouch Wave music system III - cannot get them to work together
Our internet provider just installed a new router: ORBI RBR50 at our home and suddenly my Soundtouch Wave music system III is not working anymore. It used to work just fine with the old but now broke...
Jan 16, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? This have a built in router?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
