You will need:
- I could not find any wifi specs for the product that you provided a link for in your post..
From Bose's website, I got this:
You will need:
And from another guide from bose:
If your SoundTouch system is not Bluetooth-enabled, do not set your router to "N-Only / 5 GHz Only" mode. Use 2.4 GHz or 2.4 / 5 GHz mode (sometimes called “B/G/N” or “Mixed” mode)
- Does this system operate on 2.4 as well as 5 GHz bands?
I'm not sure. I think I can infer from the information above that it does.
- What is the procedure that you follow to connect the system to wifi, I could not see this in the link you provided? In which stage during the setup do you see issues?
I have done the following:
Previously with my old (but now broken) router, I had no issues. So I am inferring the problem must be some incompatibility with the Orbi and Bose systems. I am currently trying to update my Orbi RBR50 router firmware to the latest version but it is also failing. See my other post regarding this separate issue: https://community.netgear.com/t5/Orbi/Orbi-RBR-RBS50-Firmware-Update-firmware-file-is-incorrect/m-p/1692168#M50258
Still stumped.
Have you tried to first reset the SoundTouch (On the back of the SoundTouch, press and hold the control button for about 10 seconds) and then connect your computer to the wifi from the SoundTouch, when connected you can continue with the setup steps here:
https://www.bose.com/en_us/support/article/connecting-to-a-wi-fi-network-alt-setup-wave-st.html
What is the version of firmware the new Orbi and satellite are running?
Current firmware I have for the Orbi RBR50 Router only (I don't have satellites) is V2.1.4.16_1.1.23.
I am also having issues updating the firmware. I posted on a separate thread: https://community.netgear.com/t5/Orbi/Orbi-RBR-RBS50-Firmware-Update-firmware-file-is-incorrect/m-p/1692398#M50295
Hello ekhalil,
Yes - I have reset the SoundTouch several times, including factory reset. It doesn't work. The Bose Soundtouch also doesn't show on the screen what it's supposed to show: "SETUP SEE INSTRUCTIONS"
