KFRALICK's avatar
KFRALICK
Orbi RBR50 + RBRS50 firmware stuck on V2.1.4.16_1.0.0.11
Cannot update firmware
  • FURRYe38's avatar
    You should be able to directly manually update to v44 on the RBS First. Try v210 or v212 if v44 does not work at first.
    Then you need to manually apply v212 to the RBR next. Then manually apply v44. V212 is needed before v44.
