DavidSt
Jan 10, 2019Follower
Orbi RBR50 + satellite
I just installed the Orbi AC3000 with 1 satellite at home. I have ATT Uverse so I bypassed the ATT wifi and connected the Orbi router with an ethernet cord. I had to research to figure out how to con...
Chuck_M
Jan 10, 2019Mentor
Sonos works just fine in router mode.... you do not need to change it to AP mode. I also have a boost and all works superbly.
Recommend you check firmware to ensure you are at current version and put it back into router mode.
PM me with any Sonos connection questions or tips, glad to help.
ekhalil
Jan 10, 2019Master
Correct, but please make sure if you set Orbi in router mode to bridge the ISP router, to avoid having two routers in your network.
