tekgeek1
Mar 27, 2020Follower
Orbi RBR50 and FIOS - dropping Internet
Evening,
So I recently installed the Orbu RBR50 with 2 sateliite devices - using Verizon FIOS. So I disabled the FIOS AP (killed the wireless) and use the RBR50 as the wireless hub to the 2 satellite units. I have have continuious internet dropping forcing me to reset either ther FIOS or ORBI router s few times per week. Its getting a little silly at this point. I am running firmware version V2.5.1.8 (GUI version V1.0.0.370) running in AP mode.
It got so bad tonight that I had to renamble the FIOS AP under a new nme so my son could get his homework done.
What am I missing on the configurations? Any help would be really really appreciated!
-Bruce
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry a factory reset and setup from scratch. Power off the ISP FIOS unit for 30 seconds then back on.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings - Anonymous
tekgeek1 wrote:Evening,
-Bruce
another...I wanna run 2 routers club
