Cheekymuppet
Nov 24, 2018Aspirant
Orbi Rbr50 and rbs50 keeps disconnecting
Hi I have an rbr50 on the 2’d floor of my house, with an rbs50 (satellite-1) on the first floor and another rbs50 (satellite-2) on the ground floor. Satellite-2 connects to the router and initially...
Cheekymuppet
Thanks for replying...
I’m using firmware 2.1.4.16 as I downgraded as many people said the latest firmware didn’t work with daisy chaining (should have stated this before).
How would I scan for the backhaul channel?
ekhalil
Nov 24, 2018Master
If you have a Macbook it has a built-in scanner. If you have an iPhone you can download the Apple Airport app which has a built-in scanner (even if your don't have Airport routers). I'm also sure there are also other apps for Android and Windows.
