Josh_Manton's avatar
Jul 15, 2017
Orbi RBR50 and Sonos Playbar
I have tried to use one of the ethernet ports on the back of the RBR50 satellite unit to the Sonos Playbar and it brought down the satellite unit (lost its connection to the base). The base router was no longer able to sync with the satellite. The satellite was not getting an IP. Not until I unplugged the satellite it from the Sonos Playbar did everything function normal again.
I am back to using the Playbar over wifi which works great.
Has anyone had this problem?
  • I have a Sonos playbar wired into an Orbi Router operating in Access Point mode.  No issues.
    I don't know how your Sonos is setup.  You can run in the "Boost" mode or the "Standard" mode.  Standard mode connects to your WiFi and you should not wire any Sonos devices.
    Boost mode creates it's own 2.4 GHz mesh network and you must wire only ONE Sonos device, or you will cause problems.
    Also, make sure you separate the Orbi and Playbar by a few feet at least.  They both have 2.4G radios and they will interfere.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Have you tried to connect it to the main router see if it behaves the same way? or maybe assigning the device a static Ip before plugging it back in.
      DarrenM
      • Josh_Manton's avatar
        Josh_Manton
        Guide
        I did not try to plug it into the main router. It works fine over wifi. It may be due to the amount of multitasking traffic created by the Sonos product. I'm really just alerting Netgear so they can look into it.
