Geezynz
Jan 31, 2020Aspirant
Orbi RBR50 backhaul always disconnected
Hello - I'm getting strange responses from my orbi login page, for a weeks now my two satalites are always listed as BACKHAUL DISCONNECTED, and also under attachd devices, almost always nothing is listed, or sometimes a device or two will get listed. My home has maybe 20 devices that are always connected.
Overall performance seems to have deminished also, speeds are slower and response times loading up netflix etc are taking longer than they used to.
Sorry for all the questions, any suggestions please welcome?
Screenshot attached.
Thanks
Are RBS wireless or wire connected to RBR?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I recommend you manually download v2.5.1.8 and update the RBSs first then RBR lastly:
Downloaded and installed (automatically, and then manually) v2.5.1.8 tonight. So disappointed I did. Backhaul on my satellites shows "disconnected". And I only see 4 devices out of 33 connected. However, when I open the individual apps. on my phone I can use them. Overall Mb/sec performance seems ok.
Did you update the RBS first then the RBR?
Select Remove the RBS from the RBRs connected clients page. Factory reset the RBS then resync. If this doesn't work, you'll need to factory reset the RBR and setup it up from scratch. This should resolve the problem.
radamchak wrote:Downloaded and installed (automatically, and then manually) v2.5.1.8 tonight. So disappointed I did. Backhaul on my satellites shows "disconnected". And I only see 4 devices out of 33 connected. However, when I open the individual apps. on my phone I can use them. Overall Mb/sec performance seems ok.
