kb0wwp
Feb 10, 2022Aspirant
Orbi RBR50 bricked - anything I can do?
Last night my network went down. After some troubleshooting I found that the Orbi router was unresponsive. But what was unusual is there was no flashing light on top. That's usually my first clue there's a problem.
I tried cycling the power - nothing.
I tried pressing the reset with a paperclip for 30 seconds - the green power LED never changes.
I tried the 30-30-30 reset. Nothing changes. The power LED stays green.
I tried connecting direct to a laptop with a network cable. The laptop shows "network cable unplugged" and nothing I do can change that. So obviously I can't do the "upload firmware using TFTP client" trick.
Any other suggestions?
- FURRYe38Guru - Experienced Userhttps://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
 Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
 Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
 Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
 https://www.youtube.com/watch?v=R9DLrLQrpaw
 I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
 Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
 Try nmrpflash:
 https://github.com/jclehner/nmrpflash
 If any of this fails, the RBR needs to be replaced.- kb0wwpAspirantIs this a bot? Because everything you suggested I already said I tried and didn't work. :) I guess "throw it away" is my last option. Too bad. - plemansGuru - Experienced UserYou tried nmrpflash? I've seen that work when tftp wouldn't And you can try forcing an earlier firmware to it incase that was the issue. another thing you can try is swapping the power supply from one of the satellites to the router. Maybe the power supply is faulty and isn't letting it fully boot
