Retired_Member
Sep 25, 2019Orbi RBR50 bricked during update to 2.3.5.30
Router was on firmware 2.3.1.60. I downloaded the latest firmware update, 2.3.5.30, and via Ethernet cable. Router was performing the update and got stuck for a very long time. The router was unrespon...
Apr 21, 2020Guru - Experienced User
The best way to do updates is to do manual download of FW files from NGs support site. Use a wired PC and connect it directly to the RBS and update the RBS first then connect to the RBR and load the FW lastly on the RBR using the unpacked .zip FW files. Use IE11, Firefox or Opera to do the updates thru the RBSs/RBRs web pages. Theres been some bad experiences coming from users using the auto update FW feature on the RBRs web page. Use the manual method seen on the FW update feature page.
I recommend after the RBS and RBR are updated, factory reset the system and setup from scratch. Been doing this way for a long time. Have not bricked any of my routers or satellites using this process. Works well and is a safest method.
Some of us use this method ourselves.
New FW seems to be fixing problems:
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1898060#M89482
Most problems are not FW related.
Overall, its up to you to update FW and your choice too. It's best to review the release notes as well and make the decision to update. It's your system. Use it how you see fit.
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
Lucas88 wrote:so... what is the point to have your RBR50 updated? To my understanding, the updates are supposed to fix the problems, not to create the problems. NETGEAR should have some way to unbrick the RBR50 or a secure method to update the firmware.
I have been with NetGear since WNDR3700 to NighthawkAC1900. I never had any problems before, but RBR50. I think it is time I should try some other brands.
Retired_Member
Apr 21, 2020The best way to do updates is to do manual download of FW files from NGs support site.
Bad advice
The best way to do updates to NOT to do manual updates at all. When there are critical updates for your system, NG will push them automatically to the user. No action required.
- BoilerPlateApr 21, 2020Apprentice
The ony bad advice is the ones given by VAJim. Please avoid his posts. Not helpful, valid or truthful.
Had a long history of trolling and badgering users.
- Retired_MemberApr 21, 2020
BoilerPlate wrote:The ony bad advice is the ones given by VAJim. Please avoid his posts. Not helpful, valid or truthful.
and what do you call yourself doing....??
Call you out and letting everyone know to avoid you.
BoilerPlate wrote:Call you out and letting everyone know to avoid you.
feel better?........the only one that appears to be bothered is ....you!
scroll on is your friend
Your "bothered" by users trying to help others out though. Something the forum is here for. Help each other out. Not to troll or badger users. Your long historical invalid and "unfounded statement" posts only make you look back and very incompetent. You help no body by acting like this. "scroll on? How about you avoid posting. You are of no help to anyone.
BoilerPlate wrote:Your "bothered" by users trying to help others out though. Something the forum is here for. Help each other out. Not to troll or badger users.
Bothered..? Not bothered, more like concerned. You appear not to have been around long enough to witness the true 'hoarding' of this community of one individual, all the while spewing bogus info. NG support has gone on record advises people, that if your system works, leave it alone.
The one user in particular has long advocated his/her life on the edge and the joy experienced of playing beta tester or some sort of NG employee...??
I feel most folks in here don't want to be treated like a guinea pig, but would rather seek a clear and concise explanation (not copy/paste) and then told the truth concerning firmware updates. NG used to push ALL updates. Then the whining began. So therefore, what you have today is the only updates that are pushed are those that contain critical updates. All others should be viewed as highly risky.
You my friend may not agree with my position and that's fine. Then may I suggest you support the opposing side and leave my posts to those who seek the truth.
Have a great day.
Well what users think and feel isn't of any of your concern. You have no "unfounded" information regarding what other do and do not think about when posting in the forums. From all the resolved posts seen, seems like most of the users are happy with what the community and comunity users are doing for them. No body asked you to be concerned and speak for everyone in the forums. If NetGear has problems with your one user you seem to dislike and bager all the time, I would think he wouldn't be posting like they do. You are not one to hold judgement or any one cirtical. The forum community is no the place for that. Too bad you can't understand that.
Good Day.
- BigRuneApr 21, 2020ApprenticeWell advice to not do manual updates of Orbi is good advice, unless you experience problems with current fw.
Time to cool down 😎 boys, nobody’s gonna win.
