MattDJUK
Jul 30, 2023Aspirant
Orbi RBR50 Connection Issue (DHCP??)
On FW 2.7.4.24
Hi all
I have an Orbi system (1 router and 2 satellites - which are CAT7 wired). The main Orbi router is wired to my ISP router.
No problems with it for the last 3 years at all (Orbi set up in Router Mode, also).
I've wanted to add CCTV cameras, but the recording device only sees the main ISP router IP address, and wants all Wifi Cameras to be assigned to that IP... this is where my problems start.
I've only managed to access the router via 192.168.1.1 earlier today, to add a guest network to see if that work (as the original advice from CCTV people was to turn on /off AP Isolation)...
Now the advice is to turn off DHCP. .. So i did that. And now I cannot access either Orbi networks, the router via 192 etc... NOTHING
Please help! (at the very least to get DHCP turned back on) . Our phones and devices do not recognise the IP addresses of the 2 Orbi networks. The Orbi app is rubbish.. . router not connecting to satellites either
Thank you
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System - KevinLiTNETGEAR Moderator
Hello MattDJUK ,
Welcome to the NETGEAR Community!
It is best to use your Orbi router in access point mode because it enables your entire network to use one network address. Using your Orbi router in router mode separates your Orbi network from your ISP network.
Please do the following to fix this issue:
Factory reset your Orbi router.
Switch the mode from router mode to access point mode.
Then add your CCTV devices to your network.
Please navigate to the link below for instructions on how to correctly:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settingsPlease navigate to the link below for instructions on how to change your Orbi router from router mode to AP mode:
How do I configure my Orbi router to act as an access point? | Answer | NETGEAR Support
Best,
Kevin
Community Team
