MicahD
May 04, 2018Star
Orbi RBR50 constant "Resolving host" errors across all browsers
Like subject says, lately (past 10 days or so) I get constant "Resolving host" messages when visiting websites AND when trying to go to orbilogin.com to adminster my router. The hangtime for these websites can be as much as 3 to 5 minutes waiting for the site to load, and often it never loads, just kicking back an error "Can't find this websites IP address".
Happens across both Chrome and Safari. Yes, I cleared caches, yes I restarted both the cable modem and the Orbi router. No change.
Note: This does not happen when using the satellite, only with things connected to the main Orbi router
Details:
Orbi RBK50 router with one satellite
Google chrome, latest build
iMac, current OSX build
Please help!!
PS: Orbi system is updated to latest firmware as of 05.03.18
No one can help with this?
What is the point of a $350 wifi system when it slows my wifi connection to a crawl with "Resolving host" issues constantly?
- DarrenMSr. NETGEAR Moderator
Do you have circle enabled? if so try to disable it and see if anything loads. also you may want to power cycle your modem and the orbi router.
DarrenM
