computersteve's avatar
computersteve
Apprentice
Aug 09, 2020
Orbi RBR50 daisy chain not working good with RBS50Y
I have an RBK53 system.. Both my RBS50 satellites (Ethernet Backhauled) are closer to the RBS50Y (Outdoor Satellite).  Still the RBS50Y decides to connect to the RBR50 (orbi router) instead of daisy chaining off the close RBS50 satellite resulting in a Poor connection status. Is there a way to force the RBS50Y to connect to the closest satellite? Also are any others experiencing this problem with daisy chaining?
  • Did you check to see if daisy chaining is turned on or off?
    Have you reset the RBS50Y and tried resetting it back up?
    • computersteve's avatar
      computersteve
      Apprentice
      Yeah, its enabled under Advanced Wireless (meaning it has the check on).. I have also tried factory reset it just still produces the same result.
      • Mstrbig's avatar
        Mstrbig
        Master
        I just read another forum post where the solution is this:
        Backup the RBR50 router. Hard reset the RBR50 router, the outdoor RBS50Y satellite and the indoor RBS50 satellites. After the router reset is complete, setup the RBR50 router. Skip the satellite setup. After RBR50 is complete go to add a satellite page and add the outdoor satellite (RBS50Y) first. Then add the RBS50 satellites after the RBS50Y is configured. Sounds to me like maybe there's a little bug where the RBS50Y has issues when other satellites are connected first, as I read this in several forums.
  • FURRYe38's avatar
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
  • Hey Computer Steve,
    I am having the exact same issue as you.  Did you ever figure it out?
