AzOTC
Jan 18, 2019Follower
Orbi RBR50 Downgrade Firmware V2.2.1.210
Hi Guys,
I bought the Orbi system for its out of the box ease, however I have recently noticed that my devices are disconnecting frequently.
looking into my current settings I see that people believe the firmware to be the issue.
does anyone know how to downgrade the firmware and where I can download a previous version of the firmware.
1 Reply
First off try a Factory reset on the satellites and router then set up from scratch. This isn't a FW issue. More or less a auto update issue.
Others have said that doing a factory reset has helps resolve this. Others have also manually loaded the FW files and setup from scratch.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. This can be a factor as well.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try WPA2 and AES only.If you downgrade the autoupdate will just push it back to v210.
https://community.netgear.com/t5/Orbi/Your-experience-with-Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1681722/highlight/true#M48325
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
https://community.netgear.com/t5/Orbi/RBK40-Download-Speed-Slows-Down-After-5-Days/m-p/1643475/highlight/true#M41776
