jlhill
Nov 26, 2018Aspirant
ORBI RBR50 Dropping Connection - Firmware 2.2.1.210
Our ORBI is dropping the internet connection at least daily it seems to be a common problem from the posts - anything that definitely works? Our house is 2700 sq feet. The satellite is about 30 feet a...
Deavert
Dec 20, 2018Initiate
I had the same issue since installing 2.2.1.210. I found the fix for me was to disable Circle, even though it is one of the primary reasons I chose the Orbi. I have not had a drop since disabling it and it’s been over a month now.
This is the only change I made to get it working, and I have MIMO, Beamforming, and fast roaming enabled.
- FURRYe38Dec 20, 2018Guru - Experienced User
Others have reported the Circle seems to cause problems.
Have you tired manually loading v210 FW on the router and factory reset and setup the router from scratch, then enable circle and see if the problem still happens?
This is the only change I made to get it working, and I have MIMO, Beamforming, and fast roaming enabled.- DeavertDec 20, 2018InitiateI have not tried that. Has that been documented as a reliable solution? Or any link where that has been discussed as tried and working?
Thanks!
