Stronz
Jul 29, 2021Follower
Orbi RBR50 dropping connection
My RBR50 keeps dropping packets every minute or so. The glitching is killing my iphone and zoom calls. I've nailed it down to the router itself because I will ping the router address - 192.168.1.1 and below is what I typically get. These drops happen completely arbitarily and are usually between 1 to 6 packets. I can't typically go more than a minute or two without a drop.
Here are all the things I have done that have not worked:
Changed from Auto Preamble to Short Preamble
Disabled Fast Roaming
Disabled IPV6
Disabled Daisy chaining
Changed 2.4g from Auto to channel 11
Changed 5g to 44Ghz from 48ghz
I changed modems from one manufacturer to another
Upgraded firmware to 2.7.3.22
I'm at my wit's end, help.
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk & Non-Orbi). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but Orbi devices are a bit different from most routers so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message. - olympos1625NETGEAR Employee Retired
Hi Stronz,
Good day!
Welcome to NETGEAR Community!
I would like to endorse you to NETGEAR Level 2 support team for a callback. Please DM the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Has a factory reset and setup from scratch been performed since last FW update?
Stronz wrote:My RBR50 keeps dropping packets every minute or so. The glitching is killing my iphone and zoom calls. I've nailed it down to the router itself because I will ping the router address - 192.168.1.1 and below is what I typically get. These drops happen completely arbitarily and are usually between 1 to 6 packets. I can't typically go more than a minute or two without a drop.
Disabled IPV6
