DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, ...
Aug 20, 2018Guru - Experienced User
30 feet is recommended in between the base router and satellite
DomerIN wrote:
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, showing up as having no IP address.
Both Orbis have the 2.1.4.16 firmware. I suspect that this firmware caused the problem. I don't know when it downloaded and installed automatically, but this problem came out of the blue after a year of operation.
Support had me do a factory reset of the satellite and router and the connection worked for a few days, but now it is back to dropping every hour or so.
The cable modem is functioning fine. When I connect a laptop directly to the cable modem, it picks up and IP address and is on the Internet fine.
I tried downgrading to an older firmware version but get an error that the firmware file is not valid. I've tried downgrading both the satellite and the router.
Any advice?
to begin with depending upon building materials.
naerok
Aug 20, 2018Apprentice
I've posted something similar here before but here goes nothing:
there's an issue documented in this post: https://community.netgear.com/t5/Orbi/What-you-can-expect-with-your-Orbi-system/m-p/1503034#M23257 that many people have experienced with no concrete solution.
good luck - so far the only solution seems to be putting a smart outlet / timer on your satellite(s) to reboot them once every 24 hours (I'm not joking) or rolling back the firmware (but I still see people saying they experience the same issues on the older firmware)
see this guy: https://community.netgear.com/t5/Orbi/Orbi-satellite-dropping-connection/m-p/1512445#M24230
I really don't understand the people here that think repeating the same things blindly (have you tried disabling beam forwarding? mimo? how far is the distance between your sattelites? have you tried a factory reset? have you tried spinning in a circle 4 times while holding the orbi above your head and dancing with it? have you tried to balance the satellites on your hands and sing kumbaya while entering your wifi password?) and talk down on the users that experience real issues (especially this furry guy)
It's like they have a notepad with things ready to copy/paste blindly to anyone experiencing issues here. I'm not sure if these are bots created by netgear or if these are actual people with too much time on their hands trying to get noticed by netgear to get hired as a customer support employee (it seems like when you call them, this is how they picked their support employees anyways)
Again, I appreciate people that are trying to help the community but it really rubs me the wrong way when this is most definitely an issue with the Orbi under certain network conditions and people continuously blame the user setting it up - especially after I've spent several weeks pulling my hair out debugging this issue with no solution (except rebooting satellites multiple times a day) until I replaced the Orbi system completely.
- BoilerPlateAug 20, 2018Apprentice
Well since you have moved on:
https://community.netgear.com/t5/Orbi/What-you-can-expect-with-your-Orbi-system/td-p/1503034
Why don't you let people help each other, regardless of what you think or feel, and let those who really know how to troubleshoot and help others do what they do best. Whats wrong in people helping others? Huh? Just because you could not seem to get your system working right, doesn't mean you have to bad mouth others. Maybe you should have listened or took some advise or suggestions from those trying to help. If course a shill like you probably doesn't know much and rather talk about about others. Not everyone is having a bad time like you with there systems. Just shows how little or nothing you know of how to work with networking. You have ZERO consept of home networking or how to troubleshoot and have to bash others for doing it better than you.
Talk about copy and paste? You do the same thing man. So why don't you take off and let people who are trying to help others, help in there own way. If you don't like it, too bad, then don't read it. Move along. The forum is not here for your feelings.
You said you moved on, so it's time to let go now. Say Bye.
I really don't understand the people here that think repeating the same things blindly (have you tried disabling beam forwarding? mimo? how far is the distance between your sattelites? have you tried a factory reset? have you tried spinning in a circle 4 times while holding the orbi above your head and dancing with it? have you tried to balance the satellites on your hands and sing kumbaya while entering your wifi password?) and talk down on the users that experience real issues (especially this furry guy)It's like they have a notepad with things ready to copy/paste blindly to anyone experiencing issues here. I'm not sure if these are bots created by netgear or if these are actual people with too much time on their hands trying to get noticed by netgear to get hired as a customer support employee (it seems like when you call them, this is how they picked their support employees anyways)Again, I appreciate people that are trying to help the community but it really rubs me the wrong way when this is most definitely an issue with the Orbi under certain network conditions and people continuously blame the user setting it up - especially after I've spent several weeks pulling my hair out debugging this issue with no solution (except rebooting satellites multiple times a day) until I replaced the Orbi system completely.- DomerINAug 21, 2018Guide
I'm not interested in the flame war, please don't hijack my post to battle each other.
I am interested in Netgear addressing this issue. The router and satellite are less than 30 feet apart, but I want to reiterate that I am not experiencing a WiFi problem or a backhaul problem. This is an Internet connectivity problem between my Netgear/Orbi router and my Netgear cable modem. It first happened as soon as Netgear pushed me the 2.1.4.16 firmware update. I am unable to reverse that update and unable to solve the problem.
Can Netgear help? Support just tells me to do a factory reset, which I've already tried multiple times to no avail.
Mike
- FURRYe38Aug 21, 2018Guru - Experienced User
Have you tried to apply v 2.1.4.10? I would download this version to your wired PC, diconnect ALL other devices from the rouer, modem and satellites all all others. Load the FW file, if you can get past this point, do a full factory ERASE on the router, reconnect to the ISP modem and set up from scratch. I would do some testing first before adding the satellites back.
Be sure to disable IPv6, dont' set up any QoS, Traffic Meter or Access controls. Just set up wifi. I would also set up a IP address reservation for your connected PC and if you can get to this point, reserve IP addresses for satellites as well.
Possible there is a problem with the router and may need to be replace or RMAd. I don't have much confidence in the ISP modem. Have heard other report the 500 isn't the best...any chance you can change this out for something different?
Mike
- a18valetSep 19, 2018Aspirant
As an IT Operations team manager, thank you for the candor. I am stuck in a dismal RMA process after hours burned on the phone, completing several factory resets to verify wireless radio is dead. When I stated the router was abnormally hot I was given explicit instructions not to touch, to stay away, then asked to comit a factory reset later in the script.
Paid $30 for the express option on RMA. I recomend to annyone trying Orbi be ready to return it to place of purchase asap if you experience problems. I missed that window via Amazon. They have me over the edge with bad customer service scripts, processed my $30 payment for express RMA and have sent no email to confirm RMA has been processed. Without point of entry to review case online, initiate chat online to request status only route appears to be phone call and sit in queue.
- Chi7Oct 09, 2018Star
Spot on. I just posted something similar about it being a bad system. I'm no IT specialist, but i know my way around computers and let's just all be honest, setting up and troubleshooting a router shouldn't be this difficult. I for one, would like to see better solutions that the typical suggestions, did you reset it, unplug it, etc.
- JivesOct 17, 2018Aspirant
I'm having the same issue - losing internet connection regularly, every 1-2 hours. Strong wifi signal throughout. Orbi worked great up until a week ago (don't know if that coincided with firmware update or not).
ISP came out yesterday to check it out and claims that everything on their end works fine. Cable coming into the house works, but connection is lost when it gets to router.
No modem
Firmware: 2.2.1.210
Satellite is about 35ft from router
House is 4600 sq ft
Have rebooted countless times, done hard resets, etc.
- FURRYe38Oct 17, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Might try a manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
No modem
Firmware: 2.2.1.210
House is 4600 sq ft
