Pcercega
Sep 23, 2018Tutor
ORBI RBR50, FIOS & XBOX not working in basement
Does anyone know why my son's XBOX One experiences major difficulty with downloading and connecting in our basement? We have the ORBI RBR50 router and Verizon Fios. We ended up moving all of his gaming equipment and TV screen to the top floor of our home in an ugly and inconvenient location because it would never consistently work in the basement. We're also very close in proximity to a very large stream/river. Any suggestions? I am in no way an IT afficionado. Thank you in advance!
- michaelkenwardGuru - Experienced UserHow is he trying to connect? Wifi? Wired?Basements are great at blocking wifi.
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- AC641Luminary
Have you considered using Powerline adpaters to provide a wired backhaul to the basement? If you go down this route get the pass-through type i.e. those with an in-built plug socket as they're better at filtering mains noise. I use the Devolo dLAN 1200 adpaters for precisely this.
Great idea. You can even buy Powerline kit with an access point as a part of the bundle.
For example:
PLW1000 | Powerline | Networking | Home | NETGEAR
- PcercegaTutorTo answer your questions, Furrye38,:
- I don't know what FW is loaded nor how to check that.
- I think the manufacturer & ISP modem is an ARRIS IPC1100P2 (Verizon supplied)?
- Our home is approximately 3200 square feet?
- Distance between the router and satellite is a mystery to me... We have Verizon Fios. Where would the satellite be located?
- As for the channel, we switch over to an unused HDMI channel. I.e., we access Fios Channels on HDMI1, Roku on HDMI2, and I guess xBox on HDMI3? The xBOX has literally been set up on our third floor for at least three months so I don't recall...
- There are a least 10 - 12 neighbors nearby with WiFi access.
- I have no idea how to disable the MIMO, Daisy Chain, etc. nor do I know what those are... How and where would I access them?
Much thanks for your help. I hope to have this resolved by next week... :-)Also, we did have a plug-in netgear extender but it didn't help... And I don't think he's trying to connect via wifi but I'm not sure. How would I help him check that? What would he connect with if not wifi?- FURRYe38Guru - Experienced User
FW version can be found if you log in to the Orib routers web page. Should be a status information...
The model device you report is a TV set top video box. There should be a modem or other device maybe where you get your internet from? Also do you know if there is a network router in the same modem or box? The IPC device isn't a modem or router.
The distance mentioned is how far the satellite should be placed from the Orbi router.
Channels mentioned are wifi channels being using by the Orbi router.
You can find the advanced featured under Advanced Tab/Advanced/Wireless settings on the Orbi routers web page.
You may need to seek addition in person help from someone who can help you get this set up well...
Pcercega wrote:
To answer your questions, Furrye38,:- I don't know what FW is loaded nor how to check that.
