FrankGoedschalk
Dec 16, 2019Aspirant
Orbi RBR50 firmware 2.3.5.30 is all of a sudden blocking an internet site
Community,
All of a sudden my Orbi blocks some internet sites, when I use my vpn then is evrything oké.
I'm ussing a macbook and untill 2 days ago everything was working normal.
Where can I look to solve the problem, thanks in advance Frank
Hi Plemans,
I was using cloudfare and changed it now to the default dns server and solved my problem
Thanks
1. what modem are you using?
2. have tried change the default DNS provider from your isp's provider to something like google or cloudfares?
googles: 8.8.8.8 or 8.8.4.4
cloudfare 1.1.1.1
- FrankGoedschalkAspirant
Hi Plemans,
Thanks
- plemansGuru - Experienced UserGlad to hear it! If you mark it as solved, it might help the next person with this issue.
