Vicsternz
Mar 10, 2018Follower
Orbi RBR50 firmware and Disney Circle
Says my router -Orbi RBR50 is compatible with Disney Circle and that firmware needs updating. However errors when app goes to update the firmware. What is the correct version of the firmware that I...
Starbucky
Mar 11, 2018Apprentice
You need to load firmware V2.1.2.18 for the RBR50 and RBS50 for Circle and wired backhaul. It was pulled because there are some major issues for some users. A fix is supposedly coming.
bayoyong
Mar 11, 2018Tutor
Thx! How do I do that? And should I? Or wait?
- StarbuckyMar 12, 2018Apprentice
Well up until Saturday I would have recommended you upgrade/downgrade/sidegrade to the 2.1.x firmware but I started having wifi and reboot issues. So unless you are willing to put with some stability issues to get the Circle integration I would wait until NetGear releases a new firmware.
