Vicsternz
Mar 10, 2018Follower
Orbi RBR50 firmware and Disney Circle
Says my router -Orbi RBR50 is compatible with Disney Circle and that firmware needs updating. However errors when app goes to update the firmware. What is the correct version of the firmware that I...
bayoyong
Mar 11, 2018Tutor
Thx! How do I do that? And should I? Or wait?
Starbucky
Mar 12, 2018Apprentice
Well up until Saturday I would have recommended you upgrade/downgrade/sidegrade to the 2.1.x firmware but I started having wifi and reboot issues. So unless you are willing to put with some stability issues to get the Circle integration I would wait until NetGear releases a new firmware.
- bayoyongMar 12, 2018Tutor
Ok thx again so much.
- ANBMKBMar 12, 2018Initiate
Purchased RBR50 yesterday and spent several hours last night and tonight trying to get Circle running. Finally found this message. Thanks for providing and will wait for properly working firmware.
- bayoyongMar 13, 2018Tutor
Hey Guys,
Ok, so I'm lame. My model is the RBR20. I was trying to update firmware for the RBR50. So close yet so far. Downloaded, installed the correct firmware for both R and S. Have Circle running fine. Thx again so much for your help!
