insecticide's avatar
Oct 04, 2018
Orbi RBR50 Firmware V2.2.1.210
Recently saw a firmware update to V2.2.1.210 and tried it.  The orbi now shows an invalid certificate.  Rebooted the Orbi and computer...no joy.
Anybody else see this behavior?
  • FURRYe38's avatar
    is this from the update UI or manual file download and install?
    What browser are you using?
    I recommend downloaded the recent files to your PC and use IE11 or FF browser to install them...Then factory reset everything and set up from scratch...
      • FURRYe38's avatar
        I recommend downloaded the recent files to your PC and use Safari or FF browser to install them...Then factory reset everything and set up from scratch...
