RJA1971
Oct 06, 2018Aspirant
Orbi RBR50 Firmware V2.2.1.210
Stupidly, I updated my firmware yesterday, from a rock solid system to what seems to be, a less effective network: V2.1.4.16 to V2.2.2.210.
My issues is that signal stregnth is reported to be varia...
LycanChief
Nov 04, 2018Star
After this upgrade, my download speed of any device connected using ethernet has drop. I am a 1G AT&T user and now if I am connected behind the AT&T router, everything is around 930Mbps download speed. If I go behind the Orbi, average is around 540Mbps. Something changes in this upgrade.... Any idea of what can be happening.
AT&T modem is in Passthrough mode...
Did a factory reset already! - This fix the costaly droping the wifi or internet connecting and had to refresh it...
PD: The idea of just 30days support is ridiculous...Netgear have to give better support here.... Especially when they put buggy firmware...
- LycanChiefNov 04, 2018Star
Just downgraded to 2.1.4.16 and everything is fine now! Netgear must remove 2.2.1.210
- FURRYe38Nov 04, 2018Guru - Experienced User
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
