RJA1971
Oct 06, 2018Aspirant
Orbi RBR50 Firmware V2.2.1.210
Stupidly, I updated my firmware yesterday, from a rock solid system to what seems to be, a less effective network: V2.1.4.16 to V2.2.2.210.
My issues is that signal stregnth is reported to be varia...
LycanChief
Nov 04, 2018Star
After this upgrade, my download speed of any device connected using ethernet has drop. I am a 1G AT&T user and now if I am connected behind the AT&T router, everything is around 930Mbps download speed. If I go behind the Orbi, average is around 540Mbps. Something changes in this upgrade.... Any idea of what can be happening.
AT&T modem is in Passthrough mode...
Did a factory reset already! - This fix the costaly droping the wifi or internet connecting and had to refresh it...
PD: The idea of just 30days support is ridiculous...Netgear have to give better support here.... Especially when they put buggy firmware...
LycanChief
Nov 04, 2018Star
Just downgraded to 2.1.4.16 and everything is fine now! Netgear must remove 2.2.1.210
- FURRYe38Nov 04, 2018Guru - Experienced User
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
