thomaspmaher's avatar
thomaspmaher
Follower
Mar 22, 2021
Orbi rbr50 I get error trying to check for new firmware
  • CrimpOn's avatar
    CrimpOn
    Some details would be helpful.  Perhaps take a screen shot of this message and use the "Browse" button to attach it?
    ("in-line" images created with the "Photos" icon do not appear until approved by a forum moderator, which can take hours.)
  • Same problem for me. Here’s a screenshot.
    • vajim's avatar
      vajim
      Master
      don't use the app
      login to your Orbi via PC
      • jeberhawk's avatar
        jeberhawk
        Tutor
        vajim Thank you. The RBR50 router has the latest firmware version; V2.7.2.104. I typically use an iPhone to check for firmware updates. I suppose this time the app for Apple has the fireware check error problem.
      jeberhawk
      Tutor
      The Netgear Team updated their Orbi app for iOS and fixed the "Firmware Check Error" checking firmware update problem for my RBR50 router. I can now check for an update without using my laptop.
