Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
Sep 05, 2019Guru - Experienced User
Oct 30, 2019Guru - Experienced User
Ok, so after loading v38 on my RBR50 from last week no big issues there. Today I wanted to re-test for WAN to LAN speeds with v38 loaded.
Though better results from my initial test from prior FW version, still not seeing anything near 900Mbps after a factory reset and simple setup:
BPS=499,384,824
0: 62,220,337 (497,762,696 bps)
1: 64,979,116 (519,832,928 bps)
2: 64,417,581 (515,340,648 bps)
3: 63,067,730 (504,541,840 bps)
4: 65,513,878 (524,111,024 bps)
5: 60,189,054 (481,512,432 bps)
6: 62,540,081 (500,320,648 bps)
7: 65,600,714 (524,805,712 bps)
8: 64,502,549 (516,020,392 bps)
9: 62,906,779 (503,254,232 bps)
10: 57,804,877 (462,439,016 bps)
11: 54,562,161 (436,497,288 bps)
12: 62,602,220 (500,817,760 bps)
13: 63,736,316 (509,890,528 bps)
14: 64,919,285 (519,354,280 bps)
15: 58,105,313 (464,842,504 bps)
16: 58,896,232 (471,169,856 bps)
17: 64,852,544 (518,820,352 bps)
18: 62,907,253 (503,258,024 bps)
19: 63,936,806 (511,494,448 bps)
500Mbps seems to be the average for my unit. I presume this may still effect some others as well. Not sure what is the root cause. The RBR needs HW NAT accelleration to achieve the higher 900Mbps speeds.
My RBR850 sees 900Mbps using same test methods:
BPS=948,864,032
0: 118,388,264 (947,106,112 bps)
1: 118,656,612 (949,252,896 bps)
2: 118,645,652 (949,165,216 bps)
3: 118,493,080 (947,944,640 bps)
4: 118,640,768 (949,126,144 bps)
5: 118,648,578 (949,188,624 bps)
6: 118,499,186 (947,993,488 bps)
7: 118,612,055 (948,896,440 bps)
8: 118,591,977 (948,735,816 bps)
9: 118,662,758 (949,302,064 bps)
10: 118,484,783 (947,878,264 bps)
11: 118,628,460 (949,027,680 bps)
12: 118,661,544 (949,292,352 bps)
13: 118,497,743 (947,981,944 bps)
14: 118,655,652 (949,245,216 bps)
15: 118,612,888 (948,903,104 bps)
16: 118,644,823 (949,158,584 bps)
17: 118,634,157 (949,073,256 bps)
18: 118,630,705 (949,045,640 bps)
19: 118,642,596 (949,140,768 bps)
