SLP2006
Aug 29, 2018Follower
ORBI RBR50 is not working after sertup
I need help setting up my orbi. I set it up but it doesn't seem to be working.
- Sep 06, 2018
Hi SLP2006,
Try performing the troubleshooting steps here: https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite
Kindly describe the Ring LED status during the setup process.
Blanca
Community Team
Sep 07, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
