robbiee23's avatar
robbiee23
Follower
Aug 02, 2019
orbi rbr50 is solid magenta
my orbing is showing a solid magenta halo but I'm still receiving wifi Also I have 2 satellites are connected but one is showing a amber dot when viewing it on the app
1 Reply
  • FURRYe38's avatar
    What Firmware is currently loaded on the RBR and RBS?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
