socialworker00
Sep 20, 2022Tutor
Orbi RBR50 issues
Hi,
I had my orbi for 6-7 years without any issues. The family and I just got back from a three week vacation and now I'm noticing low speeds 10-28 Mbps. Normal speeds would be 300 Mbps to 600 Mbps. I have three satellites in a fairly large apartment. All three satellites (Hallway, Master bedroom and kids room) speeds now range from 10-28 Mbps. The office has the orbi router which is pumping out speeds at 300-600 Mbps if you connect wirelessly near the office. I see no error messages on the orbi issues on the app. I decide maybe the firmware needs to be updated since I see there's new firmware available. Firmware is updated and now I see random backhaul status "Poor" from the satellites. At times it goes from poor to good ( I never had this problem before) I also see from time to time one or more of the satellites are disconnected. They reconnect but disconnect randomly. The router is still pumping 300-600 if I connect from the office. The other three satellites are 10-53 Mbps. I unplugged, reboot, routers, modem, satellites, computers, changed channels but nothing has changed. I'm not sure if the firmware upgrade made everything worst or was simply like this after I came back from vacation but didn't notice it. When i do a speed test from my cell phone in the bedroom i can see fast.com is struggling to give me a number. Normally before the vacation it would take 3 seconds.
My setting are beamforming and MU-mimo is on. Daisy chain is off. I have about 42 devices connect to wifi ( could this be it?) . Also WMM is on.
i started asking for help on another external forum but figured i should also come here for advice.
I was asked the following questions in the other external forum which i'm posting below for context.
Please see my response in bold to each question below.
router Firmware Version
V2.7.4.24
Model Ubee UBC1322
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
i'm using a Cat 8 Ethernet Cable, 2 Pack 6ft RJ45 Connector with Gold Plated F/FTP Patch Cord, Gigabit Internet Network Cord, High Speed LAN Cable 40Gbps 2000Mhz for the Router.
The apartment is about 2,000 Sq Ft, we purchased two high rise apartments and combine them together.
The router is about 31’11 from the first satellite, The second satellite is 24’ from the first satellite, The router is also 26’5 away from the 3rd satellite ( I added this one two years ago because there was little to no signal in this area of the apartment)
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡 What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
I stopped using auto years ago. Right now I am using 9 for 2.4 and 44 for 5Ghz. Sometimes i'm unsure which channel is the best.
So everyone in the building ( 22 floors , Apartments A-Z) have 400 Mbps min internet service for free. If you want more then it cost extra. I have two apartments above and below me and two at each side of me. (building made out of brick and concrete)
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
I just completed this tonight. I changed the 2.4Ghz to Auto and then the 5Ghz to 48. The satellite speeds reduced to 5mpbs so i changed the channels back to 9 and 48. I also turned off everything in the sequence you requested. Quick question should i also had turn off the satellites ? I just turn off modem, router, Mac computers . However i did not touch the Satellites.
Be sure to restart your network in this sequence: Turn off and unplug modem. Turn off router and computers. Plug in and turn on modem. Wait 2 minutes for it to connect. Turn on the router and wait 2 minutes for it to connect. Turn on computers and rest of network.
completed but did not notice any difference
I never pressed the reset button on the orbit since i purchased the unit. I will try over the weekend when everyone is out of the house. if i mess up something tonight my wife will kill me knowing she has to work in the morning.
Thank you!!
Hello socialworker00,
Welcome to the NETGEAR Community!
I understand that you are having stability issues with your RBR50 backhaul and implemented the recommended troubleshooting steps to find a solution.
Please PM the following information so I can endorse you to our support team:
Name:
Email:
Phone Number:
Device Model:
Firmware:
Serial Number:
Preferred time to be contacted:
App version:
Please provide this information as soon as possible!
I look forward to hearing from you!
Best,
Kevin
Community Team
- ekhalilMaster
I think your problem is simply bad wirelesss coverage between the satellites and the router. It can be that new radio interference was introduced in your surrounding while you were away! recommend to do the following, if possible:
- Get the satellites closer to the router or try to remove obstacles in between if possible.
- Activate Daisy Chain as this will allow the satellites to connect to each other rather than just looking for the router.
- If you can use cables between the satellite and the router then please do that.
- If you can use ethernet over powerline to connect the satellites to the router then please do that.
Hi,
So i moved the orbi's closer to each other but that didn't work. I then enable daisy chain and all hell broke loose this morning. Once i enable daisy chain the orbi was not able to connect to all three satellites. All three was showing up as disconnected. I worked on the router for about 30 minutes before I decided to give up and disable daisy chain. Once I disable daisy chain then all the satellites started showing back up. I wondering if I need to invest in another MESH system.
Thank You.
- ekhalilMaster
Wait, wait, wait, Just seen that the UBC1322 is a router with wifi capabilities, this is a problem if Orbi is set in router mode, is it?
This can cause in conflect in IP addressing and can cause the issues that you see with the satellites not connecting when in Daisy Chain.
I have an RBR50 with 8 satellites working perfectly well in Daisy Chain.
You have either to set the UBC1322 to bridge mode (https://www.melita.com/help/internet/connection-setup/setting-up-your-wireless-modem-to-router-bridged-mode/ubee-modem/setting-the-ubee-wireless-modem-to-bridge-router-mode/) or set Orbi into AP mode.
