PapaR
Dec 17, 2020Follower
Orbi RBR50 keeps going offline. Need to press sync button to get back online.
- margonellAspirantI am also having this issue, not sure if the Sync button fixes it, will try this. It is happening several times a day and is incredibly annoying
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite - vajimMaster
firmware?
