ygarti's avatar
ygarti
ORBI RBR50 multiple wifi disconnection
Hi All,
i am having some issues with RBR50 every few hours my wifi is diconnect for a few secondes and return back
I thought that the problem was with the RBS50 so i disconnect it and i was still getting wifi disconection from the RBR50
i am on the lateset FW and i already did restore to factory default and it didn't help
i don't know what to do next i tried everything i can think off
i don't want to replace my very expensive router RBK50 but i am really frustrated from this situation and dont know what to do
the person that will help me will gain eternal life :)
Thanks a lot
  • Retired_Member's avatar
    Retired_Member
    It always helps if you state which FW version you're on and how you came upon it.  Meaning, did you manually do the update or let NG push it to you automatically?
    In this forum there are several postings of unsettled FW versions and in most cases, the user upgraded on their own which resulted in having to roll back to the previous versions.
    One other item,...you may have others post here and suggest you try this and that.  If you have the time that's fine, however, if your system was working before the FW update, then chances are the new FW is the cause of your problems.  The choice is yours.
    • ygarti's avatar
      ygarti
      Hi
      i am using V2.3.5.30 which is offical FW (as far as i know)
      i did it using the Orbi admin page (i didn't download anything or at least i don't rember)
      i tried every solution that i found but nothing worked
      any sugestion i will be glad to try becuse right now the situation is not great :)
      • FURRYe38's avatar
        Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
        My RBK50 is working on with the above suggestions and on v2.5.1.8.
        ygarti wrote:
        Hi
