Elfnash's avatar
Elfnash
Tutor
Apr 25, 2021
Orbi rbr50 network components change connection to satellite
some of my devices will switch from the main router to the satellite, causing communication between devices inconsistent. For instance, my lg tv will switch. The. When I mirror my iPhone to play music, it skips and is garbled. Is it normal for the devices to switch connection to the satellite? Is there a way to make sure the tv stays connected to the router instead of the satellite?
  • CrimpOn's avatar
    CrimpOn
    Yes and No.  In devices that "move", such as phones, tablets, laptops, networking software in the device is typically programmed to scan the WiFi constantly looking for a better connection and then switch access points when one becomes better than the one it is currently attached to.  This is a part of the 802.11r standard.
    Devices that are not expected to move, such as tv's, thermostats, security cameras, etc. are typically programmed to search for the best WiFi system and stop looking once they connect.  Having a tv change connections without being powered off and back on is unusual.
    The only guaranteed method to force a device to a specific access point is an ethernet cable.  Wired devices cannot switch. Alas, physical placement of the access point and tv often makes this impractical.
    • Elfnash's avatar
      Elfnash
      Tutor
      Does this mean that every day when I turn the tv on it will search for a connection? Would it be better to leave the tv on all the time?
      • CrimpOn's avatar
        CrimpOn
        My understanding is that the tv should select the same access point every time. Surely one of them provides a better signal to the tv than the others.  If the tv is selecting different access points, it might be worth gathering some data.  I do not know if the tv provides information about the WiFi signal. (My phone, for example, reports the WiFi band (2.4G or 5G) and the transmit & receive link speeds.)
        The Orbi "app" provides a little information about the link speed.  Each time after the tv connects, the Orbi should report which access point it is using and the link speed achieved.  Are they similar (or different)?
        To confess even more, I do not know if a tv being "off" really means OFF.  It might not be displaying a picture or sound, but it could be "alive".
        This is a real puzzle.
