winsrfr's avatar
winsrfr
Orbi RBR50 not talking to Network Solutions website
My Orbi RBR50 has stopped talking to my website provider, Network Solutions on Friday afternoon.  I can't access my website builder tool nor can I check my email.  Very frustrating.  I can get to my website and check my email if I hardwire my computer straight to my cable motem so I know it's the router.  I can also go to any other website no problem.  Any insight would be helpful.
Thanks, Paul
  • FURRYe38's avatar
    Was it working before? if so, and you didn't change anything on the Orbi, I presume the issue would be a web site service issue, not a Orbi issue.
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    • winsrfr's avatar
      winsrfr
      Everything was working great Friday morning.  Now, everything works as usual with every other site except this one
      • FURRYe38's avatar
        If other sites and such work and this one site doesn't, it wouldn't be a router issue.
  • See if you can ping it and tracert to it. The issue could be with your DNS, or it could be a security setting, like blocked sites. If you haven't already done a factory reset, you can look into those.
