moomats
Mar 08, 2019Tutor
ORBI RBR50 not working and led ring doesn't light up
Help!
My Orbi RBR50 (router) stopped working. I have tried to reset it to no avail.
The led ring light doesn't turn on too! My system consists of RBR50 and two RBS50s. The satellites appear to be working because their lights are magenta.
Help!
Thank you,
MM
The RBR50 has power? (i.e. the LED on the back at the bottom is GREEN?)
How exactly did you "reset" the router?
- moomatsTutorThe power led is green and I reset the router by pushing in the reset button.
Thank you for your help!
MM- CrimpOnGuru - Experienced User
I attempted a reset once and neglected to hold the paperclip in long enough. First the LED turns orange (for a LONG time), and then it begins to blink. I saw the orange, thought "done", and pulled the paperclip back out. Watched the Netgear video and realized I was not waiting long enough.
