johnl4th's avatar
johnl4th
Orbi RBR50 port 443 blocked
I have an Orbi RBR50 and when I run stuff on my web server it says 443 and 80 ports are blocked.
I configured port forwarding to and from that static ip. It just stopped working...
  • Windows Server Essentials was broken. It was the Anywhere Access website so... it doesn't work well.
    No wonder they got rid of it in Server 2019.
  • CrimpOn's avatar
    CrimpOn
    Maybe more explanation will make the situation clear.
    • There is a web server inside the Orbi LAN, with a specific IP address.
      Can you share what sort of web server?  on what platform?  (Windows, Linux, etc.)
    • On the Orbi Advanced Tab, Advanced Setup, Port Forwarding, ports 80 and 443 are forwarded to the IP of this web server.
    • The firewall of the computer the web server is running on has ports 80 and 443 open to the web application.
    What is the specific error message?
  • FURRYe38's avatar
    • FURRYe38's avatar
      What was the problem? Just wondering.
      Enjoy. :smileywink:
      • johnl4th's avatar
        johnl4th
