nadams69
Feb 16, 2019Follower
Orbi RBR50 problem hard wired to Sky Q box
Hi any help appreciated
My set up is sky q router with wifi turned off , wired into athe Orbi RBR 50 in AP mode.I have a satellite RBS50 hard wired to the RBR50 router. All this is working perfec...
Feb 16, 2019Guru - Experienced User
The Sky box has to be connected to the Sky Q Router I believe..I would contact Sky Q for help and support regarding there equipment.
My set up is sky q router with wifi turned off , wired into athe Orbi RBR 50 in AP mode.I have a satellite RBS50 hard wired to the RBR50 router. All this is working perfectly as a wired backhaul and good connection between the two of them.
My problem is i'm trying to hard wire the router to my Sky Q box, with it connected I go into sky network setup and say I want to hard wire but it doesn;t work. I have the option to manually input ip address, subnet , router ip and dns but don't know what to input.
I have tried both the ip adress of the sky router and orbi router but no success.
Any ideas?
Thanks
Nick
