Will726
Feb 10, 2020Tutor
Orbi RBR50 range problem
Two days ago I replaced my AmplifyHD mesh router with Orbi. Orbi RBR50 to be exact. I have a 4 story home (including the finished basement). Old. Plaster walls. I was not happy with Amplify...
Will726
Feb 10, 2020Tutor
I will try all these things and also post the model of my ISP modem. Regarding the factory reset. Like I said, just got this system in the last two days. Do you really recommend doing a factory reset?
Will726
Feb 12, 2020Tutor
You had asked for my Modem make/model. It is: ARRIS Group, Inc. TG1682G. Any issues?
I am getting closer. A reset has improved things and I am continually tweaking settings now to see if my devices get better performance. I'll report back once I land on the best settings. Its a guessing game though. I am reverting and not following some advise here as I'm seeing better results using '6' for a channel and also 100% for 2.4 and 50% for 5. I'm starting to wonder if I should just try to shut down the 5 all together. It's very strange though some devices not 10 feet from each other get very different results.
- FURRYe38Feb 12, 2020Guru - Experienced User
That mode is your modem working in? Router or is it bridged? Your Model modem has built in wifi and a router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIf what you have currently set up is working better. Try it out for a couple of days to check operation and stability first before making any major changes.
- Will726Feb 12, 2020Tutor
My modem is already in bridge mode. All wifi on it is off. Yeah, I know I need to let these changes bake for a bit.
k, just checking.
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
:smileywink:
