Su1tan's avatar
Su1tan
Orbi RBR50 refuses to update to Firmware V2.5.1.16
My RBR50 Orbi router is still in V2.1.4.16, and when I check for update it states "No new firmware version available."
So I went and downloaded it from NETGEAR to manually update the firmware by uploading the file "RBR50-V2.5.1.16.img"; However when I attempt to do so I recieve the error "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
Specifically, I'm downloading ther Firmware update from this page: https://www.netgear.com/support/product/RBR50.aspx
  • And yes I did try to update to V2.2.1.212 per the V2.5.1.16 patchnotes. still says the firmware is incorrect.
    (And before anyone asks, yes I am painfully sure that 1. my Router is the Orbi RBR50 AC-3000, and 2. I am downloading the firmware from the RBR50 AC-3000 page)
    • plemans's avatar
      Do you have version 1 or version 2 of the rbr50?
      When you're downloading the file, are you extracting it? some just download and open the file. If you're on windows you have to extract it by right clicking and "extract all"
      Have you tried installing 2.2.1.210?
      I'd also recommend updating the satellites first.
      • Su1tan's avatar
        Su1tan
        I'm assuming it's V1 because A) it is still in 2.1.4.16 Firmware, which means according to the patchnotes, I would not be able to ever update my Version 2 since Version 2 apparently only goes down to 2.3. And to get 2.3. you need to have 2.2.1.212. Basically it would be literally impossible for my router to be Version 2 unless someone in Netgear did a big dumb.
        And I can assure you, I still tried to upload V2, and V1, firmwares... all of them. I'm still getting the same "incorrect" Firmware issue.
