dave_n_s
Apr 30, 2023Aspirant
ORBI RBR50 resets but SSID reverts to prior one and admin password reverts
I have an Orbi system of my own working well and set up without problems, after factory reset (bought used)
The problem system is one donated to a charity that I volunteer for. It's an RBR50 and one satellite.
The router appears to reset fine, gives an SSID of ORBI99, but then after a short time, reverts to what it was before I reset it.
The reset indications are as described - green power light turns orange then starts to flash after which I allow it to reboot.
I'm doing the set-up via the Orbi Android app.
What's causing the router to revert please and how do I resolve it?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- dave_n_sAspirantHi,
Thank you for your reply.
I can't determine the firmware because, as it reverts to the previous configuration inc SSID shortly after the normal factory reset, it sets the admin log in to whatever the donor had it set to.
Is there another way of determining the firmware?
This was connected to exactly the same router / ISP with the same cable as my own Orbi system of a similar generation (Starlink Gen 1) and I've reset / tested a number of other older Orbi systems using the same connection.
My suspicion is that there is a Firmware issue as it is clearly broadcasting a default SSID and then with no action on my part reverting to the pre-reset one.- FURRYe38Guru - Experienced User
Can you not log into the RBRs web page to see FW version on the page?
Can you walk thru the setup wizard after pressing the reset button for 15 seconds then release, after the top ring LED slowly blinks WHITE, try walking thru the setup wizard at 192.168.1.1 with a ethernet connected PC and web browser here. Do this with the RBR disconnected from the ISP modem/router.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeTry option #2 first...
