mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
danny07
Jan 20, 2021Tutor
After upgrading to 2.7.2.102 I clicked on the button to add Special Parental Controls, which said a reboot was required. After reboot, the entire section for parental controls is missing. Any ideas how to remedy this besides a reset?
Jan 20, 2021Guru - Experienced User
v2.7 handles parenal controls differently. v2.7 versions are for US region users only.
Access controls are located under Advanced tab/Security. If you need Circle support, you'll need to revert back to the FW version you had loaded that supported Circle, I believe v16 or v40 support Circle.
Please post about this over in the Circle forum for help and information regarding Circle:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
danny07 wrote:After upgrading to 2.7.2.102 I clicked on the button to add Special Parental Controls, which said a reboot was required. After reboot, the entire section for parental controls is missing. Any ideas how to remedy this besides a reset?
