mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
Jan 20, 2021Guru - Experienced User
v2.7 handles parenal controls differently. v2.7 versions are for US region users only.
Access controls are located under Advanced tab/Security. If you need Circle support, you'll need to revert back to the FW version you had loaded that supported Circle, I believe v16 or v40 support Circle.
Please post about this over in the Circle forum for help and information regarding Circle:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
danny07 wrote:After upgrading to 2.7.2.102 I clicked on the button to add Special Parental Controls, which said a reboot was required. After reboot, the entire section for parental controls is missing. Any ideas how to remedy this besides a reset?
vajim
Jan 20, 2021Master
FURRYe38 wrote:v2.7 handles parenal controls differently. v2.7 versions are for US region users only.
Why isn't this version offered when users check for updates in the web login area?
- FURRYe38Jan 20, 2021Guru - Experienced User
It's offered if ones system has updated to v60.
- vajimJan 20, 2021Master
FURRYe38 wrote:It's offered if ones system has updated to v60.
Not true ....again..sorry
and if it were true how would someone NOT have v60?
Is true, once I had v60 on my RBR50, v102 appear as an available download in the RBRs FW update web page. Others reported seeing this as well:
ALL avialble FW versions are on NG download site for manual download and manual update as well. Up to users to upate or not.
Enjoy. :smileywink:
